false
USE CASE
Kubernetes monitoring
Get a clear view into the health of Kubernetes clusters and workloads to expedite troubleshooting and drill down quickly to reduce mean time to resolution.
Lorem Ipsum
OVERVIEW
Powering containerization and portability
Kubernetes has become the standard for deploying containerized applications and achieving portability across multicloud environments. But this comes with a lot of operational complexity when trying to isolate problems. DevOps and site reliability engineering teams need to visualize and monitor performance of the entirety of Kubernetes deployments.
HOW WE HELP
Intuitively manage performance in Kubernetes environments
Monitor Kubernetes behavior
Get an immediate, comprehensive, out-of-the-box hierarchical view of nodes, pods and containers.
threat detection
threat-detection
Understand context
Context is key. Splunk helps you bring Kubernetes data together with infrastructure data, application data and logs — without context switching.
Tap into AI-driven analytics
Troubleshoot faster using AI-driven analytics that automatically surface anomalous pods and services.
threat detection
Splunk Advantage
Understand Kubernetes performance faster than ever
Kubernetes Monitoring Kubernetes Monitoring
Fully-automated Kubernetes monitoring
Monitor the full stack with zero-touch configuration and automated discovery.
dynamic cluster map dynamic cluster map
Dynamic cluster map
Visualize cluster health, performance correlation and interdependence.
Watch the Kubernetes 101 Webinar
Accelerated root cause analysis
Explore the tech stack with a fast pivot to intelligently alert and direct on issues.
Monitoring Microservices on Kubernetes
RELATED PRODUCTS
One platform, end-to-end observability
RESOURCES
Explore more from Splunk
Get started
Consolidate tools, optimize spend and get the most from Kubernetes.
